Test pipe CEL light
Test pipe CEL light
Hey guys i have an 06 with a Invidia 70mm test pipe and the rest of the car is stock. i had it on for about 700 miles and the CEL for the o2 come on when i drive low speed at low rpms. what can i do to fix this?
Have you put the non-foulers on there? If not get two and do that...
But that still might not fix your issues. I have a MY06 and throw a CEL with my Test pipe and non-foulers...
Its just because MY06+ have a more sensitive ECU / 02 sensor.
what are non-foulers? the only thing that i know it has is the hole where the O2 Sensor goes and if you look inside of it you see a the like a small pipe where the sensor goes have a the wool around it
https://www.s2ki.com/forums/index.php?showt...&#entry11953366
heres another one that i had made helped both of my buddies with my07
I've been lagging on this since cel doesn't bother me much but I'm just going to add a resistor into the signal wire of the 02 lets see if that tricks the ecu. I'll try it and report back.
