template for seibon mugen replica
is there a template for the seibon mugen replica to install.
just got mine and i need a template to put it on. I have read that its the same mounting points as the honda wing.
So my question is are there pre tapped spots for it in the trunk or does it have to be drilled.
Thanks Jeremy
Thanks Jeremy
Former Sponsor
Pop your trunk and look on the corner, there should be a hole cut on the underside skeleton of the trunk where you are suppose to tap and then drill. Hard to explain, but if you pop your trunk and see you should see it.
ok thanks thats what i figured just wanted to make sure before i went to drilling.
also is it only supposed to have 1 bolt on each mount to hold it to the trunk seems kind of weak to hold up to triple digit speeds and the abuse of sometracks?
Former Sponsor
Ya, one bolt and you can should put double sided tape on the fronts to a) not scratch your trunk lid and b) to secure it further.
It will hold up, cause the authentic Mugen wing is also held by only those two bolts and double sided tape.
ok good thats what i planned just didnt want to shoot in the dark with it and figured someone on here has gone through it and figured i get their opinions thanks shadow
Jeremy
Jeremy
are the two pre tapped holes on the very edge of the trunk.
If not does someone have a picture of the holes that need to be drilled out
dont want to go drilling into myu trunk and not have the right spot drillled thanks
Jeremy
Jeremy
Former Sponsor
http://forums.s2kca.com/showthread.php?t=15569
Has pictures etc for the OEM AP2 wing, but it has the picture of the one hole you need closest to the edge of the trunk.
2QYK4U
Member S2000 Classifieds and For Sale
28
08-11-2008 07:56 PM
