SPC camber kit
SPC camber kit
I want to correct the camber in the rear, i'm drop in kw'3 with Ce28 stock offset. Any body using this kit? HOW good is it?
Whats other option do i have?
Thanks you.
Thanks you.
Are you saying that you have too much camber now?
The SPC kit works well to get MORE negative camber.
I'm not sure if you're talking about reducing camber because you're slammed. In that case, I'm not sure that it will help you.
I think he is talking about bringing camber back to 0 degrees??? If tthats the case then it will work, I dont know how much more Camber you can get out of them, but I know you can get it back to -0.
When I had mine lowered I could not correct it more than -1deg. of camber after the SPC was installed I could go back to -0deg. (not as good for the track, but better for tire wear when I was not tracking the car).
