Skunk2 70mm Test pipe
Originally Posted by SmattaHead,May 2 2008, 06:27 AM
Reviews??? anyone?
performance gains?
dyno?
butt dyno, even?
performance gains?
dyno?
butt dyno, even?
This is a nice piece that will allow you to blow flames with increased efficiency at 70mm.
IMHO, NA very little to no gain. Boosted will see gains of up to 20 rwhp over the CAT depending on the setup.
I ran my 70mm with boost and the difference was noticeable in the butt dyno and nose.
You will need to do some work with the O2 sensor/bung to avoid check engine lights.
I was not running a skunk2 pipe.
I wonder how much it weighs. I have seen test pipes like that weigh from 2 to 9 pounds. It does have the more expensive weight saving machined flange.
Bryan@BerkTechnology.com
06-26-2009 11:56 AM
