Recommend me a clutch setup for CT S/C Kit
Going with the CT Engineering kit for the AP1
Which clutch/flywheel/pressure plate would be the most suitable in terms of reliability and suitable for that power band?
The car will be a dedicated weekend warrior so stiff will work, but not necessary.
Thanks
Thanks
If you're on a AP1.. Re-use the AP1 flywheel (12-14 lbs) or something lighter, completely up to you. (avoid aluminum flywheels)
ACT Pressure Plate or SOS Kit
OEM Clutch disk
OEM Clutch disk
SOS or ACT HD pressure plate + OEM clutch disk. Drives great and holds as well as you'll need and then some. Oh, and a bunch more reliable!
Originally Posted by theprophet36' timestamp='1425316368' post='23524461
I liked the SPEC Stage 3+ clutch kit with AP1 flywheel when my AP2 was supercharged
Sounds like you have no need for a stiffer pp, so go with a stock pp, stock disc, and a lightweight flywheel might be the ticket.
I like the Clutch SOS is offering, what about their bearing?
Flywheel I think I'll stick with AP1 OEM, what about pressure plate then...
Price isn't a issue, I'd like reliability and ease of use > the power factor
Thanks guys
Thanks guys
There are several threads as already pointed out on which options for ~400whp supercharger solutions, I can save you the leg work, the favorites and consensus are you have three good options:
1. SOS sport clutch (http://www.scienceofspeed.com/produc.../Sport_Clutch/)
2. ACT pressure plate with OEM friction disc (this will have oem engagement characteristics but will be harder on your drivetrain and your leg since the pedal will be harder (http://www.hardtopguy.com/store/prod...cat=145&page=1)
3. Ballade FI clutch (http://www.balladesports.com/product...-sports-clutch)
I personally own the SOS sport clutch but might try the Ballade once this one goes out since it has a really good price, looks promising and their stuff is always great quality. The SOS is nice that it keeps pedal effort relatively light like stock for those of us who live in congested bumper to bumper traffic areas, however it still chatters a little when cold and has a slightly more abrupt engagement than stock.
