Rebuilding engine
Rebuilding engine
ima be rebuilding a f20c engine here soon. Im going to be rebuilding the bottom end for sure, and Im not sure if Ill do the Head depending on the damage/condition of it. whats thes best bang for buck on parts? I might be doing forced induction down the line, so IF can afford it Id like to get it prepped for that. I wanna keep a budget under 5k if not 4k, if possible. and were the best place to order these parts from. thanks for the help!
I think it's the h22 rods and pistons, with the k24 crank and do a resleeve on the block. with all new gaskets. shouldn't run you more then 2500 bucks. and strokes the motor to 2.4l pretty safely. only thing you should get a piggyback or stand-alone computer.
Former Sponsor
Are you familiar with the gains from that stroker setup?
very familar I have read everything i can on it. i am doing it myself this winter.... there is ppl running it n/a and ppl running it turboed. don't know anyone with it supercharged. it can handle the abuse if the motor is built right. more and more ppl are doing it becuase it has held up, and is cheaper then buying a stoker motor "kit"
here read up
http://www.superhonda.com/forum/f32/anyone...198/index2.html
https://www.s2ki.com/forums/index.ph...ic=538548&st=0
it's a lot of reading but worth it. and you will have a good start to it. you can pm me with any questions.
