Rear Hardtop Brackets
I'm trying to figure how to remove the interior plastic moldings that gain you access to rear brackets where the hardtop pins fit . Would appreciate any how to . Thanks ahead of time . Roshton
You have to remove the panels behind each seat that have the hooks on them (pull the little flap on the hooks to expose the 8mm screw). Then you can remove the side panel that covers the bracket.
Thanks I will take another look is this flap plastic u are talking about that exposes screws and is it located at the top of the panel . One member wrote in and mentioned I have to remove soft top at each side I can't understand this . Regards Roshton
If you pull the back of the seat forward, you will see two hooks in the panel that stick out (they are for a bungee cord to tie things down). There is a small flap on each hook that pulls down and will expose the 8mm screws.
