rear end
Crush collar failed on mine causing the pinion to retract and shred a number of teeth on both it and the ring. One of the pieces even busted through the diff cover causing it to leak all the oil. Pretty lame
Think puddymod and the inline conversion are your best bets... Just wandering, if you change oil regularly and only track your s2k (no hard launches) is there minimal chance of it failing? What if you don't drift but give it a cheeky slide in the wet coming out of a junction lets say... but NO dry sliding or drifting!!
well i dont know much about diffs but you might try looking into diff conversions i believe they sell conversion kits for nissan diffs. It might be more expensive at first but i think it would pay off to start with a strong diff instead of strengthening a weak one. Please chime in if im wrong
I am building two drift rears for them based off the factory rear. One with a Carbon LSD and a NOS set of 4.57R gears. The other will have a few other custom made parts made and installed as well.
Like any part of any car everything has it
