random koni shock question
right now im lowered on skunk2 springs and koni yellows.
in order to go down to the lower perch on the shocks, i'd have to take them all apart again right?
its about a half inch lower on the second perch, correct?
thanks
-Nick.
thanks
-Nick.
If you jack up the car completely and the suspension sags to a point where the spring is no longer compressed, then you don't have to take it all apart. Since the spring is not compressed, there is no force pushing down, so you can pry open the C ring and move it down. Watch out for the weight of the spring though. That will fall due to gravity.
But if the spring is still compressed, then you should take the whole thing off or risk losing a finger...or worse.
Originally Posted by Nick.,Mar 26 2009, 09:08 PM
hmm even when the shock is out of the car with no weight its still compressed.
i guess i have to just take it all apart.
whats the difference in height?
Well, it doesn't hurt to give it a shot.
