Q300 too loud. Can I fit silencers or something?
#32
Hahah, we all love to brag on our cars... its like people having to show you pictures of their children.
Honestly man, you sound a lot like I did when I installed my Q300. I did every combination under the sun that I mentioned before to try to calm it down (save tearing up a new exhaust and welding in a new mid-resonator) and none made me happy.
My resolution was to run PLM header, Berk high flow cat, and stock exhaust. Tame and quiet under normal driving but it gave a (still tame) deeper growl under WOT and 6-9k sound excellent without making you sound like a ricer to the rest of the world.
I bought a second stock exhaust so I could do the quick disconnect modifications for autocross purposes... perhaps you should do the same and do the loop-pipe mods that someone posted a few posts back to see how it sounds? Then you aren't chopping up your stock exhaust in case you end up not liking that either.
I would take videos for you, but I am supercharged now and that adds a significant amount to the in-car volume.
#33
i hope you realize that if you are going to move onto exhaust#2, that you should demo it before you buy it (WITH AN HFC!)
Driving far or paying someone to demo it is a lot cheaper than shelling out $600 and then figuring out you hate it and also the disappointment.
I'm personally on exhaust #4, but i was very fortunate to have been able to trade my exhaust straight up for another a few times.
When i realized how useless my car became with the ____ exhaust, because the car was no longer enjoyable to drive stomaching the cost of a $#,### exhaust that i demoed and liked wasnt so bad if youre satisfied in the end.
I think a new mid muffler would do wonders, but I'm only 25 / 75 on whether it would be enough. And if it's not, I've wasted more money, time and probably reduced it's 2nd hand value even more.
Driven it 4 times now, and every time before I get moving I think I'm ready for the wall of noise, and then 2 mins in I think "this has GOT TO GO", LOLz.
#34
The Q300 is obnoxiously loud without the stock cat, since the resonator is so undersized. If you have a test pipe, it's even worse, but there's way less drone. There is quite a bit of drone with an HFC, but it's not so much that many people would complain about it (every exhaust drones at some RPM). However, if you have your car tuned, with a lower VTEC engagement, then it will be louder in the area where VTEC is engaging early. For me, that's at 3600 RPMs, so every time I accellerate with much throttle, it's friggin' loud!
#35
The nice thing about the UK exhaust mod is you can change it to suit what you're looking for. The larger the pipe you add the louder it gets but I've yet to read any posts about drone no matter how large of a pipe that was used. So you can start out with a 22mm pipe and move up till you find what you want.
If someone wanted to get fancy, they could make a 3 piece pipe so you could change out the middle so a different sound could be had in just minutes. So the two outer pipes would be as large as the pipe on the muffler and all you would change is the middle(washer type) piece for a different sound.
ROD
ROD
#36
ROD
ROD
I'll post back my thoughts once it's done
#37
Why not get an apexi ws and be done with it. I see all these "my exhaust is to loud" threads and nobody mentions the ws exhaust. I have a testpipe and apexi ws and its the quietest car with an aftermarket exhaust I've ever owned, no drone, no rasp just a nice growl at wot.
#38
I went through your whole ordeal once too. I absolutely hated the Q300 with a Berk 70mm HFC. The fitament was crap too. My solution was exhaust number two, Tanabe Medalion Touring with the smaller diameter Berk HFC. I could not be happier now. This exhaust is perfect sounding and fits awesomely like it should! I was able to sell my Q300 for a decent price, but had to pay nearly double for the Tanabe
#39
The hks dual sounds incredible. It has the perfect tone and is barely louder than stock. I hate loud exhausts. Believe the hype on the hks!! It's true. One can also be had for around 500 bucks used. Mine is being paired with a test pipe, not sure what a cat converter difference would make. Your head will not be busted from drone like invidias.
#40
