PSS9 Install help
PSS9 Install help
Trying to take the coilover apart to install the OEM top hats, I saw a thread with pictures on how to put it all together but my main concern is the knob... how do I remove the knob? Just the 21mm nut?
Thanks
Thanks
the dial with the 1-9 numbers on it needs a 1.5 mm hex if i remember correctly. the base of the adjustment knob yeah i just used something big enough to fit, not sure if its 21mm or not. it locks up against the nut that you're suppoesd to put under it. if you have more questions feel free to pm
... the thread is called Good price for Bilstein PSS9s at this site, $1149 shipped
my post is here and this is the relevant picture..
hope that helps
Originally Posted by s2ka' date='Dec 24 2005, 06:28 PM
I suppose it would probably make sense to mark it with a longer line so that there is no question about the direction. When taking it apart for the first time, mark it like this so you know exactly how it was assembled from the factory.
finished installing, did anyone having trouble adjusting the rear ride height? the front from the factory was pretty low, i was trying to set the rear to a even height with the front so i can get my alignment done.
