Oil temp gauge
I have one installed. I got the Defi blue racer gauge. i installed it with a boost gauge. For the oil temp gauge you need a oil filter adapter so you can attach the oil temp sensor. Heres the link to an example:
http://www.nipponpower.com/view.phtml?f_ca...r+Block+Adapter
You place this inplace of your oil filter and then your oil filter goes on the adapter, just periodically check to make sure its not leaking, ive had mine over a year and no problems as of yet. Hope that helps.
sorry not to jack this thread, but does anyone have any experience using the Greddy rad hose adapter for installing water temp gauges?
http://www.nipponpower.com/product.phtml?p=467&mmk=212
Originally Posted by iam7head,Jan 6 2008, 11:09 PM
just don't use a taper brass fitting in home depot in oil pressure sensor port and you'll be fine
Originally Posted by negcamber,Jan 6 2008, 10:17 PM
It will likely crack your block.
https://www.s2ki.com/forums/index.ph...pic=554754&hl=
While putting your water temp probe in the return line does in fact give you a water temp reading the best place to put a water temp robe is in the block.
On the oil filter side of the block there is a freeze plug.
This plug is the same place that Honda puts in an oem block heater
Remove the freeze plug and tap this piece.
Reinstall the plug and then screw in your water temp probe.
This position will give you the most accurate temperature and quickest response.
Slows2k had a thread a long time ago that showed exactly where this plug is located.
I have mine installed there and it shows temperature increases much faster during warm up then a probe place in the return hose.
08s2000CRbackinblack
07-09-2011 09:41 AM
vaamntxoovzeb
08-24-2010 09:18 AM
