OEM Hardtop
OEM Hardtop
I have an 01 S and I'm currently looking at buying a oem hardtop for it. Will I run into any issues with installation since its an early model or is the oem hardtop universal for all s2k's?
If it's an OEM top, you will not have any issues with it. There are a few resources here with detailed instructions that may be helpful. If you're buying from Hardtopguy, he will also supply you with directions as well as the defroster harness for any year.
Just take your time and everything will be fine. Loosen the rear bolts (3 of them I believe) on the hardtop and mount it. Make sure it's aligned, and then tighten. Easy. Good luck.
Originally Posted by FilthyAp2,Oct 29 2009, 10:59 PM
DO NOT TAKE APART YOUR ROLL HOOPS!!!!!!
Those are bolted down, if you take them apart they will never go back together like OEM.
Pretty straight forward as others have stated. The scariest part for me though was when I read that I had to take a hammer and center punch to my car. No biggie though, you'll see.
