Mugen Replica Rear Seal
This install is driving me nuts! Any ideas? The seal keeps flopping off the window, I tried heating to corners so they form better but it didn't help much. Thanks! -Kyle
Thanks, but I have read that thread a few times. I was wondering if anyone with experience had a detailed solution of what to do with the rear window seal. I have read ~10 install threads and none of them go in to depth with that, and my seal is pretty annoying.
Former Sponsor
If its just the corners, you can use adhesive glue to make them stay down. The tension of the window seal makes it flop up.
Alberto
Alberto
Depends on which seal you have and which window. When I first got my lexan window the seal had a protective film that you had to remove to expose the pigment (easy to miss) with the glass window I just got it didn't have this so all it took was a firm press into the glass edge and some patience. Either way try either looking for the clear film and pressing it it firm againts the edges annnnd take your time.
Good luck, hope this helps
I bought this secondhand but not installed. I think what happened is the guy I bought it from removed the film on the seal and it dried out before I got a hold on it. I am leaning towards using epoxy/gorilla glue or window weld to get the seal to stick to the window which is polcarbonate. LMK what you guys think.
Update: I had some success with an mixture epoxy I bought at Fry's, it is messy though. My Window Weld was dried up and I don't have $ for more... so until next week. Do I sand the indentation down for the window?
wisdom
09-11-2010 12:35 PM
jdmkings
03-07-2010 04:04 PM
RL1924
10-03-2008 12:29 PM
minhdinh85
08-12-2008 04:54 AM
hokiemax
11-26-2007 01:10 PM
