Muffler Tips
unscrew the nut on the bottom of the ap1 tip, pull it out, and slide in the ap2 lip then screw it back on.
and you can find ap2 tips from the marketplace for about $40-$60 depending on the condition
Just a heads up GeniusTek, if you're putting AP2 tips on an OEM AP1 exhaust, they don't fit without modification. The AP1 tailpipe is too long so you'll have to cut off about 1.5" - 2" otherwise the AP2 tips will stick out too far. Also the set screw has to be swapped for a longer one. The AP2 tips are held in place with a mounting tab welded to the AP2 tailpipe to prevent rotation or loosening from vibration. The AP1 tailpipe lacks this so you need the longer set screw for a really tight fit.
