Mounting takatas with hard dog roll bar
ok so im in the proccess of getting some bride vios seats along with some takata harness
i dont have much experience with seat harnesses so i had a couple of questions
with the hard dog roll bar is a long version of takatas required since the harness bar does not have a location to mount the eye bolts to, so i would have to wrap the long version around and mount in somewhere else?
if so where is the best place to mount the sides of the takatas and the two shoulder straps?
thanks guys
thanks guys
you need the short version takatas. It wraps around the harness bar.
I have also seen people drill a hole thru the harness bar and install the eylets and others have welded on tabs to clip the harness.
^ I disagree. I have Bride Vios buckets with Takata 4-points and the Hard dog rollbar. If you want to wrap around the bar you need the long version along with two of the metal pieces that they wrap through. http://www.discoveryparts.com/cgi-bin/stor...t=hhard&pid=580 All the Takatas come with the hardware to mount via eye bolts. (the "short" Takata will not be long enough to wrap around the bar)
I suggest you get that bracket and wrap around the harness bar. Most least intrusive method and works very well.
For the lapbelt, you can use the stock seatbelt mounting location for the left side. For the right side, drill a hole in the transmission tunnel and mount an eye bolt. Make sure to use reinforcement plates for everything that goes thru the body...
where can i get some of those?
Originally Posted by milkman2089,Jan 7 2010, 08:59 AM
where would those brackets be placed when mounting? just behind the seat?
You can get that mount from Schroth http://www.schrothracing.com/store/Competi...orcement-plates
Originally Posted by 99SH,Jan 7 2010, 11:13 AM
Nothing goes behind the seat! Those brackets go under the transmission tunnel. You only need 1 for the lap belt (right side mount). For the left side you can put an eyebolt where the stock seatbelt lower mount is.
i know the dangers of misused seat harness and just dont wanna kill myself!!!!!
