Mounting Point For Harness?
correct, a roll bar is the only way to safely do a multi point harnesses. I have seen a few people mount it to the bulkhead behind the seats but at that point you would have been better off getting a cage with harness bar.
To do it right in the S2000 you need a 6 point.
Shoulder harnesses attached to a roll bar. Lap belt uses lower seatbelt mount and seatbelt receptacle mount (attached to seat) or eyebolt with backing plate into transmission tunnel. Sub straps on either side of the frame rail using eye bolts and a backing plate.
Originally Posted by MurderS2K,Jun 8 2010, 09:45 AM
very good info - do u have n e photos of your setup man?
This document was useful for my install, and I highly recommend Schroth harnesses, they come with all necessary hardware including eyebolts and backing plates: http://www.schrothracing.com/docs/Schroth_...n_Checklist.pdf
I picked up a custom made stock roll hoop that had a metal bracket that bolts to the roll hoop. It worked just fine with my 4 pt harness, but since than I have replaced it with a Harddog roll bar and and getting a 5 pt harness. (side note: I have for sale a stock roll hoop, the plastic housing, and the bar with mounting hardware for sale, pm me if you are interested)
milkman2089
01-10-2010 12:17 PM
