Lowering Springs A Problem?
Ok guys, so I have decided to put lowering springs on my 01 S2K. I have done a ton of research about installing them. I seems easy, but after talking to my buddy when he was putting my new tires on, he said I was a pain in the ass and not worth it. I was looking for some opinions, suggestions and experiences. Is it as much of a pain as he says or is it as easy as it seems? I am planning on doing it myself.
It looks easy. The only 2 things that worry me are compressing the springs and removing the top hat nut. I only have hand tools so hopefully the top hat nut isnt on there too bad.
Wouldn't that mean that the spring is then at near full compression? If this is true, (the spring at rest (car on the ground) is not at near full compression) using the method above wouldn't really make any difference as the suspension is not in a neutral state, or do you want it almost fully compressed?
I guess I fail to see what preloading the suspension will accomplish?
You can rent a spring compressor from any standard auto store. I wouldn't tackle the job alone without it. Two people certainly can though.
Overall the job is not difficult, and definitely "worth it". Should only take a couple hours.
Preloading is for the bushings, not the springs or shocks. You want to preload the corner to a height at, or slightly above, where the suspension will sit once on the ground. I preload with the other 3 corners on the ground to mimic the correct load. I try to jack up the one corner to slightly above where it would sit while on the ground. You can make a reference mark on your body (with tape) before jacking the car up to ensure you preload to at least that height. When installing lowering springs, you need to preload even higher since again, you want the preload height to mimic what the ride height WILL be when it sits on the ground.
The best method would be to lower the car to the ground, then tighten everything, but it can be difficult to get your hands in there.
I honestly wouldnt even do it, but it depends on your "wants" for your car. Dont take my post to heart its your car and you should do what you want. Springs were my worst mod ever. Screw springs and go straight to coils if your planning on getting coil overs. Coils are 100% easier to install. Its basically the same process but you just take off the strut and then replace it with the coil and no taking off a spring and loading it. But yes do be careful taking off the lower control arm bolt. Mine cross threaded due to some jack off over tightening it. That bolts 15 bucks.. lol
