Looking For A Brake Duct Kit For AP1
Old 03-05-2008 | 02:01 PM
dsddcd's Avatar
Default Looking For A Brake Duct Kit For AP1
Well I have been searching for a Brake Duct Kit to add to my AP1 and all the post I found referred to companies I could not find such as C&T. Is anyone making a kit with abs or fiberglass bumper adapters for 2.5" or 3" ducts with high quality hose and backing plate adapters that direct the air into the center of the rotor not the face?
I know there are plenty of DIY but I would rather buy one than go through the trouble for making the components I want. I just don't have the time or will to tackle it if I do not have to.
Thanks
dsddcd
Old 03-05-2008 | 03:05 PM
00wreckedS's Avatar
not sure if this helps, but chargespeed makes these
Chargespeed FRP brake ducts
Old 03-05-2008 | 03:09 PM
dsddcd's Avatar
Yes, we are geting warmer, they look really nice but am I carzy to think that 300 for two small peices of plasitc is crazy. I know i said I was short on time but for $300 for this peice only I will make my own.
Thanks
Old 03-10-2008 | 03:10 PM
iam7head's Avatar
there's a racing company make alot of functional brake duct, they just came out a set for ap1 bumper, comes with a duct, mount and all the shebang
Old 03-12-2008 | 06:00 PM
tinkfist's Avatar
^ http://www.quantummotorsports.com
Old 03-12-2008 | 07:04 PM
Sideways's Avatar
This is the C&T set. He made very few of them before the infamous CTAE intake manifold. https://www.s2ki.com/forums/index.ph...ic=421692&st=0 Don't click this link unless you have time to laugh your ass off.
The company has been dissolved.
The dust shields were made of a special high temp resistant fiberglass. The final product flunked my Laguna Seca trial with R4 pads. Both front rotors cracked completely and needed replacement to drive. Two inch diameter tubing is apparently not enough volume for the cooling needed.
Old 03-12-2008 | 11:27 PM
S2FARSI's Avatar
I am confused. Are you saying that the ducting somehow decreased the strength of the rotors, helped in some manner, or did nothing at all?
Old 03-13-2008 | 12:49 AM
Sideways's Avatar
It was inadequate. If it had been adequate air flow the rotors should not have self destructed.
Old 03-13-2008 | 01:08 AM
S2FARSI's Avatar
They would have destructed without the ducts, correct?
Old 03-13-2008 | 02:41 AM
MikeyCB's Avatar
I'm curious about this as well, is it possible that they actually did the job well enough to cool the rotors and the heat-cycling resulted in the cracking?
Quick Reply: Looking For A Brake Duct Kit For AP1
