KW Clubsport
Old 08-21-2008, 06:04 AM
s2kpearlwhite's Avatar
Default KW Clubsport
my KW CS will be arriving next week. Can i seek feedback from fellow KW users on the following?
1. Should I get the optional top mount or stick to stock? Will very much prefer a smoother ride for DD but not to the extent of compromising its track's performance.
2.Can anyone care to share their settings? I will think there is a optimal standard settings for track. Such as ride height and stuffs.
Old 08-22-2008, 05:00 AM
ok i just found the answer to 2. in the suspension shootout article sometime back. There is a recommended manufacturer settings which is if im running on CSC3 tires.
AM I right to say if im intending to go R compounds on the track I can safely go for a stiffer setup?
1.Begging an answer to this question, Does the aftermarket top mount makes A LOT more noise than stock?
Old 08-22-2008, 05:13 AM
negcamber's Avatar
Wish I could help on 1. but I stayed with OEM.
Old 08-22-2008, 12:40 PM
a_zepeda926's Avatar
i dont th ink very many people have these coilovers yet as they are relatively new. i too have the stock topmount, but thats because the v3's dont have the option. i would use the topmount it comes with. those coilovers are supposed to be pretty harsh/track suited so i dont think youll notice much more discomfort just from the topmount. i know this is kind of irrelevant, but i didnt notice any more noise with the pillowball mounts on my supra.
Old 08-22-2008, 05:10 PM
urBan_dK's Avatar
Aftermarket top mounts are metal and considered a wear item (they need to be replaced periodically). For any sort of DD, I'd recommend the OEM with rubber bushings.
Old 08-22-2008, 05:30 PM
WindchaserS2K's Avatar
if you are using the OEM top on the KW clubsport why don't you just buy V3 cause you are defeat the whole purpose of it.
Old 08-22-2008, 08:08 PM
thanks for the feedback guys.. point taken.. guess i will be getting the top mount after all!
Old 08-25-2008, 06:57 AM
just installed this coilovers. inital impression, its so soft compared to the tein monoflec i was running on ! how on earth is this gonna survive on a high speed F1 track is anyone guess. But in case being the noobie I am and screwed things up, heres my settings, front/rear (0, 075) for the bump and rebound settled at 8 clicks from the stiffest.
Old 08-25-2008, 03:08 PM
have you tried other settings? on my V3's you can really tell a difference from just a few clicks. if its too soft for you, then try adjusting it.
Old 08-25-2008, 04:09 PM
It come with a pre-setting, you should just start with that and why would you set the compression at 0 in the frt??? and 8 clicks from the stiffest on the rebound?? you are almost at full open and again why would you want to do that??
Quick Reply: KW Clubsport
