Koni's & Swift springs, Which notch?
Old 06-21-2008, 03:17 PM
Butch777's Avatar
Default Koni's & Swift springs, Which notch?
I picked up a set of Koni's and plan on running Swift springs.
I usually have dropped my vettes about 2"s with Koni's.
I like the firm but roadable feel.
What would the Swift's drop, plus lowering it a notch on the Koni's, drop be all together??
And how would it affect my alinement? Would I need additional parts to get it alined??
Thanks, Butch
Butch777 is offline
Old 06-21-2008, 05:04 PM
harrrrry's Avatar
I have the exact same combo. Koni yellow shocks with swift springs. I have the spring seat sitting on the lower perch of the shock and it's a pretty good drop. The top perch of the shock is similar to stock height. With that said, swift springs give you a 0.9" drop on the front and 0.75" drop on the back i think. So lowering it on the shock should give you at least an additional 0.5" drop.
harrrrry is offline
Old 06-22-2008, 08:11 PM
Butch777's Avatar
Thanks for the reply.
So your over all drop was about a inch and a half??
Butch777 is offline
Old 06-23-2008, 05:11 AM
harrrrry's Avatar
That is what it would seem but it's not. I don't have a stock height to compare it to but the best thing I can tell you is it gets rid of the gap nicely. I can squeeze one finger in front and about 1.5 in the rear.
harrrrry is offline
Old 06-23-2008, 05:19 AM
notamaster's Avatar
I agree with the second perch. I have the same set up and I recommend the second perch. The drop is perfect with bearly a gap o the tires. And yes you will have to have your cars alinement redone once you finish.
notamaster is offline
Old 10-05-2008, 12:01 AM
speedstar808's Avatar
hey guys,
to confirm: you are on swift springs using koni's on the 2nd, correct? how is the ride quality? harsh? near stock? any rubbing??
thx
speedstar808 is offline
Old 10-05-2008, 05:12 AM
notamaster's Avatar
There is no rubbing with stock wheels. The ride is a little stiffer but that depends on your setting on the koni shock.
Old 10-05-2008, 02:37 PM
upsdoc's Avatar
What settings are you running on the Koni shocks?
upsdoc is offline
Old 10-05-2008, 04:46 PM
notamaster's Avatar
1/4 turn from full firm and on the second perch.
Old 01-27-2009, 03:49 PM
02S2Grand's Avatar
What wheel/tire size are you running?
Do you rub?
Rolled fenders?
02S2Grand is offline
Quick Reply: Koni's & Swift springs, Which notch?
