Koni Install Questions
I have a few questions regarding the install of Koni Yellow shocks.
How do you transfer the spring perch from the stock shock to the Koni?
In the thread i saw the rear shocks were not correctly threaded for the stock bolts, has this been fixed?
I plan on using the fronts at the lower perch with my skunk2 springs and the rears at the normal perch, will i need a spring compressor?
Thanks for your time.
-Nick.
-Nick.
The spring perch is just press fit in the shock. Use a piece of wood and tap on it with a hammer. The perch will come right off. There is no problems with the threads. The stock bolts fit no problem. Mine just had some dirt in the threads. I ran the bolts down with some WD40 before I installed the shocks and had no problem.
I dream of S
05-25-2005 01:04 PM
