Intake manifold fail
Well, I had my valve cover and manifold chome plated - both look beautiful! But the manifold will not seal. Appentently the thin chrome cover on the mounting surface is uneven. don't know if anyone else tried this and/or if there is a work around. My tech reccomended using it as a paper weight after taking it to a performance machine shop to see if it could be resurfaced. The machinest reccomended finding someone with a CNC mill that would do the tooling necessary to hold the manifold while its milled. The tooling alone would cost an arm and a leg. Sigh, I depressed, but on a more positive note - the valve cover looks awesome.
Did you try installing a Hondata intake manifold gasket? I would expect it to conform well enough. Just make sure you follow marcucci's install procedure to make sure it lasts!
http://www.s2000.org/mods/insulator/
Not reccomended. It is very doubtful an even mounting surface with less that ..002 inch difference fron front to back and top to bottom could be achieved with hand sanding. My performance shop and tech both reccomended against this approach with an aluminium manifold.
Well, you will trade a stock intake that works for a chromed one that doesn't? I'm guessing you would like to try some custome mounting techique of your own. I,m all ears, if you have any ideas on materials or methods. Personally, after research, Permatex makes some sealant called the "Right Stuff" that will replace an OEM gasket. I suppose that would be worth a try as well.
If anyone else has had experience with any of the Permatex products, I am all ears, as that will likely be my option of last choice after Hondata.
thanks for the complement! As my engine bay now stands, I will be looking to "up scale" the engine bay from the current titanium to something a little more flashy. (I know, its a taste thing and I'm one of those old motor heads, so don't flame me). I have noticed with deep interest the work you have done on heatshields and cooling plates. I was wondering if you had thought about doing a beauty panel for the drivers side of the engine bay. something that would cover the brake/throttle cable and other hoses and tubing between the intake manifold and the fender, perhaps emulating the heat shield you make for the exhaust side. It's just an idea, and mayby not too practical (think show car), but something I would be interested in.
