Innovative mounts
Innovative mounts
Can someone please tell me the torque settings for the following bolts that are recommended for the Innovative motor mount set:
1/ Bolt that passes through the grey 'U' bracket engine mount bush?
2/ Bolt that passes through the grey 'U' bracket tranny mount bush?
All the other mounting hardware I will use the OEM torque settings.
Thanks.
Thanks.
43 Ft-lbs is what I was told by innovative a few years ago. Mine needed alittle more than that. Just torque them bolts down until the silver collar that the bolt goes threw touches each side of the grey U bracket. That’s all it will need.
