Info and DIY CAI intake theory/links?
So I've been reading alot here and one of the number one issues i'm reading on against a pure metal intake is the heatsoak. Why couldn't someone just clamp a metal tube to the OEM plastic intake arm and go custom, aka allow a better location than some of the 300+$ intakes out there(wrap around radiator?).
Another idea I was debating was using an aftermarket cone-filter, clamp it to the stock plastic intake arm and then run hosing to the faux-foglight location with a shield right before the clamp on the arm.
Thoughts, ideas, links to good places to buy misc intake parts?
I really don't want to throw down cash for something that's just going to soak in the heat anyways.
I've seen some of the airbox mods as well, but I don't understand how someone hasn't figured out something that lines up with the rectangle on the stock box (vacuum cleaner regular recangle head w/ hose? Another though I had was simply cutting the inside bottom of the left side and prob 1/3 of the right side and putting a grill over that area as to only get bottom air inside the box.
As I understand it at autozone/advanced auto type places there are separate pieces that can literally be welded to make an intake (spectre or something?)
Any information or ideas are highly useful to me Looks not important (i can always hide it.)
Originally Posted by s2kVTAK,Jun 8 2009, 06:27 PM
i just bought a k&n FIPK off ebay for $230 shipped. proven gains from 5-10hp. minimal heat soak as well.
Love that plastic tube. Is there any way to buy just that? that would rock with a ah.... 90 degree elbow pointing down to start off and a cover around it below the bend.
Originally Posted by s2k aok,Jun 8 2009, 08:07 PM
oem + snorkel = best performance for cheap
Sorry about the image quality
I took the tube from inside the stock airbox and am showing it put in place instead of the "vacuum head" style one already on there.
The idea is that you can addon to it on the side so that the entire air supply is
"colder" than the stock location.
