How to install: Deep dish steering wheel
I had a few questions on how the wheel was mounted so I did a little write up.
I wanted to keep the steering wheel in its OEM or shorter position (relative to the dash). Since the wheel has a deep dish (3") I had to do some improvising. Below are the options you can use to mount an aftermarket wheel to you car.
1) Short hub with a standard quick release. This allows you to keep your horn function and have a quick release. You will have to remove your SRS reel. This means the SRS light will stay on in the dash and the passenger side airbag will NOT fire in the case of a crash. When used with a normal steering wheel (no dish) it’s roughly the same length as OEM
2) Another way to do it is to buy an normal hub and thin quick release. This allows you to keep the horn function and the SRS reel. When an SRS resistor is used you wont have any SRS lights come on in the dashboard and the passenger side airbag will fire in the event of a crash. When used with a normal steering wheel (no dish) it’s roughly the same length as OEM
3) I used a short hub with a thin quick release. This worked perfect. I was able to keep the wheel at the OEM position even with the 3” deep dish. HOWEVER I had to remove the horn functions inside the short hub and thin quick release to get it all to fit together. This means I could NOT use of my horn and I had NO SRS reel.
NOTE: REMOVING THE AIRBAG IS UNSAFE, REMOVING THE SRS REEL IS UNSAFE, DISABLING THE HORN IS UNSAFE.
The 3ed option is for someone who really wants the deep dish look without loosing the OEM length. I never used the horn ( I think it sounds bad) and wasn’t concerned about the light in the dash. So that’s what I opted for. This option is not for everyone, I’m aware.
So if you want to use this wheel (or any deep dish wheel) with out losing the horn and SRS light. I would suggest you use option 2 at the cost of the steering wheel being approx 3” closer to you in the car.
If any info in here is inaccurate please tell me an i'll change the post.
Thanks for reading
Thanks for reading
fto222
06-16-2009 08:54 PM
GDM S2K
Member S2000 Classifieds and For Sale
10-27-2006 06:58 AM
