Help Stage 3 clutch =(
So I can drive manual cars easy but damn stage 3 clutch is shit. Ive had this car for 2 days and its fun but damn i suck at shifting. 1st Gear stop and go kills me. Mostly every time I cant smoothly shift and the s2k shakes but then i put more gas and ease off clutch and im good to go. but when the car shakes my foot shakes and shakes even more because of it.
There is like a fine line between Sexy shift and oh crap you're stalling.
How I shift is big toe ball pressed down slightly and I can shift. Like less than an inch it feels like. Then I stop pressing my big toe ball. and good to go.
To give you an idea.
Black=Pedal
Green=Sexy shifting zone
Red=oh no your stalling.
Im having more problems with 1st gear.
If anyone drives a s2k with stage 3 clutch in it. Id appreciate some advice.
Thanks.
Black=Pedal
Thanks.
Did you put in a lighter flywheel too? I once tried to drive an AP1 with an 8 lb flywheel and it took me 4 tries to even get it out of the parking spot. Even then it felt like I was either stalling or doing a burnout.
The owner seemed to have an okay time getting the car moving 100% of the time, but it was by no means smooth. I think what you've got is mainly an issue with building new muscle memory and wearing in the new clutch.
If all else fails, try flushing your clutch fluid or polishing the slave cylinder pushrod.
I had a stage 4 from competition clutch put in last year. It definitely felt a little more "notchy" at first, but because the pedal feel was still somewhat soft it wasn't as bad as most would expect.
I have the same clutch in my civic with longer clutch pedal movement, It has a more on/off feel to it probably due to the longer gears.
I remember almost stalling the first time I got in the civic with the new clutch, after a few days it felt good, but it's almost impossible to have the factory s2000 clutch shifts every single time.
i have competition clutch stage 4/flywheel on a civic. pedal was stiff like a rock when 1st installed, after a long breaking in period it got softer but still stiff.
you just have to change your driving style as in reving higher when u take off so it doesn't shake. i drive mine daily in peak traffic and alot of up hills, so dont stress.lol
And to you too for asking smad!
Unless youre boosting a lot or doing a heavy amount of track and autocross events i dont see the need to run a pucked clutch. Especially unsprung. In my opinion if you need to run a pucked style clutch anyway you may as well run a twin disk.
Ive had many cars with puck style on/off clutches and im over it.
Alot of the guys have run the act pressure plate with an oem disk because of this. My self included. Slightly stiffer pedal feel with a lot more clamping force.
If you ever want to switch all you have to do is swap disks.
