Hardtopguy clutch kit
Why do the components for his kit make it a "preferred kit" for F/I S2K's????
Hardtopguy clutch kit:
ACT p/p
OEM disc
ACT or S2K flywheel ( i cant decide ACT or AP1)
OEM throwout bearing
ACT clutch kit :
ACT p/p
ACT clutch disc
ACT flywheel
no bearings
ACT p/p
OEM disc
ACT clutch kit :
ACT p/p
ACT clutch disc
ACT flywheel
no bearings
ACT p/p
OEM disc
ACT clutch kit :
ACT p/p
ACT clutch disc
ACT flywheel
no bearings
ACT p/p
OEM disc
ACT clutch kit :
ACT p/p
ACT clutch disc
ACT flywheel
no bearings
It's preferred because it retains excellent driving characteristics. The pedal feel is just like stock, except a little more pressure is required to modulate the pedal. That combined with the clamping force and torque capacity, and it's easy to see why it is loved by both NA and FI S2000's.
I have read several threads about these some older but - can someone confirm that the current hardtop guy set up does or does not make noise/chatter ?
clarification would be appreciated. thanks.
mines relatively new and its no louder/quieter than when i had a stock one...
i have the ACT PP, ACT 8ish lb. Flywheel, OEM disk and OEM beatings... you can hear it when youre idling and in neutral but its not loud
i didnt experience a discernable difference between the 2. the noise is really nothing to be concerned about, I think you're imagining it to be louder than it is
