Hardtop weather stripping
Old 06-03-2024, 03:52 PM
Dibsen's Avatar
Default Hardtop weather stripping
Put my hardtop on over the weekend
When I test fit the new window weather stripping, I only went to the bottom of the hardtop, left a pretty bad gap.
I should have run it all the way down to the drain
Better but not great
On the passenger side, I ran the weatherstripping all the way to the drain, but the seal is still bad.
Anyone have any clever tips for sealing this up better?
Old 06-03-2024, 08:00 PM
spider2k's Avatar
does it not use the oem seals? i remember when we did my BiL's mugen replica we used the oem metal plates and rubber seals.
Old 06-04-2024, 12:58 AM
Scigheras's Avatar
If you want a decent seal you have to use OEM (style) seals
Old 06-04-2024, 08:13 AM
Dibsen's Avatar
Anyone have a pic of what the oem weather stripping looks like in that part of the door?
Old 06-04-2024, 08:39 AM
spider2k's Avatar
it looks like your soft top. i'm saying we used the 3 metal plates and seals that go on the soft top. soft top up, same shape as hard top around the glass.
what about this?
https://balladesports.com/products/h...strip-seal-kit
Old 06-04-2024, 06:27 PM
Dibsen's Avatar
what about this?
ive bought products from Ballade before, I’m not a fan.
This portion right here, this is what the Forbidden seals don’t address. I need to see what I can come up with.
I don’t have any long distance trips coming up but I’m thinking about trying to mold something up. If anyone has any ideas, I’m willing to experiment.
Old 06-04-2024, 07:18 PM
spider2k's Avatar
find a junker soft top. use the metal rails and foam seals. screw 11,12,13 to the hard top, then snap 5,6,7 on. heres a set of used ones but you need the backing plates.
https://www.ebay.com/itm/22609185560...Bk9SR-L2veb8Yw
Old 06-07-2024, 04:43 AM
Dibsen's Avatar
The OEM hardtop seals sell for $200 per side. One of the reasons I’ve avoided those is because I don’t have an oem top, it’s a Mugen replica. I called Forbidden before ordering and they said this was what everyone uses. I wish they would have included a small detail about running the seal tucked under the bottom corner before running it up and around the window. I’m probably going to order another set of seals from Forbidden, that another $100 for what should be about $30 of rubber.
Old 06-07-2024, 09:53 AM
spider2k's Avatar
the oem seals still fit. do it once the right way.
Dibsen (06-07-2024)
Old 06-07-2024, 12:19 PM
Dibsen's Avatar
Just got off the phone with Forbidden, great customer support. We talked for a while on what the problem was and how we could fix it. They even offered to sell me another set at cost if that was what was needed.
Quick Reply: Hardtop weather stripping
