View Poll Results: Does your hardtop rattle?
Never rattled
11.11%
Used to rattle, but is now fixed/rattle free
55.56%
Rattles
33.33%
Voters: 9. You may not vote on this poll
Hardtop latches and strikers / catchers? Are they the same for SOFT and HARD tops?
Old 04-09-2014, 08:32 AM
6262's Avatar
Default Hardtop latches and strikers / catchers? Are they the same for SOFT and HARD tops?
Have a little bit of rattling on the hardtop from time to time, just wanted to know if the latches / strikers are the same for the SOFT TOP AND HARDTOP? or are there different ones.
I recalled the latches were different, but cannot find any info on that anymore.
I have read the threads on the diy fixes on the mild rattling for the latches, but that doesn't seem to be a long-term solution, just a short term fix.
Any feedback is appreciated.
Old 04-09-2014, 09:02 AM
ForNgoods's Avatar
The strikers are different. Hardtop versions are a little thicker. I've had them installed in mine but it hasn't eliminated the rattling. Guess I just need to adjust my hardtop more.
Old 04-09-2014, 10:11 AM
Kenny_Stang's Avatar
Mine doesnt really rattle as much as it squeaks when going over uneven pavement. I have OEM Hard Top with OEM Hardtop strikers and all OEM mounting equipment. I haven't really bothered to fix the issue, but its on my "to do" list.
Old 04-09-2014, 10:41 AM
dfvs2k's Avatar
No Rattle with HT strikers , but do have minor squeaks over uneven pavement.
Old 04-09-2014, 10:44 AM
Mordiiax's Avatar
Hardtopguy sells updated strikers. Does anyone know how they differ from some non-updated version?
Old 04-09-2014, 12:42 PM
I think they are just thicker (if you're asking the difference between soft top vs. hard top strikers)
Old 04-09-2014, 05:43 PM
slalom44's Avatar
The squeaking can be eliminated by putting enough Shin-Etsu grease on the rubber seals. The car frame flexes on uneven pavement causing the seals to rub.
Old 04-10-2014, 10:57 AM
J Schmidt's Avatar
There are hardtop latches and hardtop strikers, as well as, softtop latches and softtop strikers. And as mentioned above an good adjustment and shin-etsu grease lessen the noises of the hardtop. Good luck.
Old 04-12-2014, 01:21 AM
Mordiiax's Avatar
I was refering to the updated hardtop strikers versus, i presume, standard/old hardtop strikers.
Old 04-14-2014, 10:51 AM
doddg's Avatar
1. Can you use what is on your AP2 if you go to pick up a hardtop to set it on and latch it down to get it home, and then worry about getting "updated" or thicker ones later?
Quick Reply: Hardtop latches and strikers / catchers? Are they the same for SOFT and HARD tops?
