Hardtop Bracket bolts
Can anybody tell me the dimensions of the following three bolts in the picture below. I am missing these for my hardtop bracket. Can I pick these up at my local hardware store? And the bottom two bolts are already equipped in my stock car? All help is appreciated!
They should be 6 x 20 mm bolts, that is for the three upper bolts that mount to the upper hardtop, assuming the manufacturer of your top copied the oem setup like most do.
The bottom two bolts are 6 x 20 mm, and 8 x 20 mm , I don't believe both of those bolts are on the car in stock form, one might be but not both. You might just pick up both in case you find that your car doesn't have them, saves you a trip back to the store.
You can pick up spare bolts from any hardware or fastener supplier, you should use washers on all five bolts. If you need to know the thread pitch I can check that for you.
heebster
01-11-2016 11:35 AM
