ground control.
Old 05-18-2006, 09:54 AM
[AP2-2NV]'s Avatar
Default ground control.
just wondering, i am plannin on getting a koni/gc combo with gc top hats.
so i got on the search and tried searching around but alot of the posts i get are outdated, from way before ground control became a popular option.
so, i'm wondering, how is the ride? i want a firmer more controlled ride, but i dont want the infamous ricer bounce.
also, how do they do on minor bumps? the coilovers on my old car handles big bumps very well but it picked up every little single bump in the road and at times it was kind of annoying.
Old 05-18-2006, 10:22 AM
vbb
vbb's Avatar
I don't have that setup, but from what I've heard it's very good, and the ride quality is great.
BTW, that "ricer bounce" that you're talking about is caused by people driving around on springs with blown shocks that have completely lost their dampening ability... which wouldn't be a problem with a Koni/GC set up.
Old 05-18-2006, 10:25 AM
[AP2-2NV]'s Avatar
yea that's what i thought. either blown shocks or springs too stiff for the shocks. but i hear the koni's are good to 500lbs. i'm most likely going with a 400/350 setup so i assume i should be fine.
Old 05-18-2006, 10:39 AM
B.C.'s Avatar
My setup is 15% (ish) stiffer than stock. Lowered and no problems.
Old 05-18-2006, 11:03 AM
[AP2-2NV]'s Avatar
cool thanks. good to know.
Old 05-18-2006, 11:56 AM
vtec9's Avatar
GC on konis is an excellent setup, especially for the money. I have koni yellows on my GTI and they perform well, although I have broken 3 of them due to very strong springs (within the specs though), hard track runs, and shitty roads. oh and all three were broken in only 25k miles
Old 05-18-2006, 05:39 PM
iam7head's Avatar
Go with GC with koni yellow, great combo
make sure to get the special perch with that set up.
not sure how well the stock shock will handle the drop tho'
Old 05-18-2006, 05:56 PM
S2Koupe's Avatar
what spring rates did you use.
and did you cut out the lower perch from the stock shock? does it just come off?
Old 05-18-2006, 06:39 PM
BulldogS2's Avatar
how about just the GC, how long do you guys think that would last? i had that on a 2000 si and it lasted for almost a year, of course i did not race, hard launches, etc.
Old 05-18-2006, 06:59 PM
TheChemist's Avatar
Back-Cracker,
Looks like you have GC's with stock shocks...
The GC/Koni setup allows for quite a bit of adjustability. I went with the "street" setup 375 f and 325 r springs and Koni adjustables, and I couldn't be happier. If you track alot you may want to go with a stiffer spring combo. I'm not really lowered...approx. 1/2" all around, I didn't want to bottom out/scrape everywhere. I'm running 3/4 of max on the Koni's.
I would like to give a big thumbs up for the Spugen guys and their GC/Koni group buy...they are great guys, and good reps. for the S2k community.
Quick Reply: ground control.
