gears
so i have a 02 s2 and i wanting to do gears for my next mod....so how much am i lookin to spend and what all do i have to look for?? and whats the price range wit install?????
give me some ideas//advice
i do barley any interstate driving if any if that helps
thakns guyz
thakns guyz
Probably a little over a thousand if you can install it yourself. If you dont do any highway driving then 4.77's are the best choice. www.hardtopguy.com sells them pre-installed in differentials, it will cost about $2000 with the core charge of $1000, so when you get his differential with the 4.77's in it, install it, send your stock one back to him and you get your $1000 back. He does very good work and is very good to deal with.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
depends what you consider hard. it shouldn't take more than a couple of hours. and its MUCH easier if you have a lift. I wouldn't attempt it if its your first time changing a differential. have someone that's done it there with you to guide you through it or just have a shop do it.
I pulled it down myself and it was first time taking down a diff. Its not to hard its actually pretty self explanatory. theres a guide I know on here I partial followed but for the most part you take out all the bolts around it till you see its free. Its not that bad of a job.
Have HTG do the install for you. A gear install into a diff is NOT easy to do correctly.
I had HTG do my 4.77's and have had ZERO problems.
Originally Posted by qbmurderer13,Mar 8 2008, 10:39 PM
Probably a little over a thousand if you can install it yourself. If you dont do any highway driving then 4.77's are the best choice. www.hardtopguy.com sells them pre-installed in differentials, it will cost about $2000 with the core charge of $1000, so when you get his differential with the 4.77's in it, install it, send your stock one back to him and you get your $1000 back. He does very good work and is very good to deal with. ![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Originally Posted by s2000Junky,Mar 11 2008, 11:54 PM
$1000 for a whole diff with gears is a hell of a deal, unfortunately you have to deal with shipping and charges, wonder how much these are? So if someone like myself wanted a diff with a different gear choice such as 4.44 for my application, do you know if he provides these in his package as well?
