FULL OEM Hardtop Hardware..
I own a Forbidden-USA Mugen replica hardtop and would like to know EVERYTHING I need for a complete install. I know Hardtopguy sells everything but im not sure what I do and don't need. Basically I'm asking someone to piece together all the components needed to do this (including the bolts and whatnot). The only thing I don't need is the seals. If someone can do this I would appreciate it VERY much.
1.)front driver and pass catcher (like softtop has) I believe each side is held on by two screws
2.)rear driver and passenger stricker (bolts to hardtop-3bolts each side I believe- its the parts with the handles attached)
3.)rear driver and passenger catcher (bolts to car frame-inner side frame on each side in which the previously mention strikers fit into-4 bolts on each catcher)
4.) the mugen doesn't have glass so don't worry about drefroster cables from the oem,ect
5.) if you are using oem hardtop seals- make sure you have the seal track that screws into the hardtop on which the seals fit on top of. there's a rear seal too if you didn't know already.
that's about it, if you end up buying the rear catchers from hardtopguy then would you mind trading rear catchers since mine didn't come with the defroster cable (they are authentic oem)- you won't need it anyway since you have the mugen. pm me about anything if you have any more questions. I can easily take my top off and provide pics if needed (that's what she said lol)
