Front brake line mod to avoid swaybar arms
So I have a bit of a potential issue. I installed a nascar style swaybar (pretty much exactly like the gendron monster bar, but 1-5/16" diameter) on the front, and the arms rub on the bottom of the rubber brake line. I haven't tried 'tinkering' with it yet, but it looks like if I were to unbolt the clamp that holds the line to the shock body it would still rub, and probably worse. I'm probably going to upgrade to steel braided lines, but I don't know if there is enough slack to route the brake line differently so it does not rub on the swaybar arm.
Has anyone else had a similar issue, and if so, how did you fix it? It may be possible to unbolt the brake line clamps on the caliper and the shock body and move the line so it doesn't rub, but I'll have to see if there's another way to secure the line and still have enough slack in the line to allow full steering movement.
Thanks for any input you can offer!
trackrabbit21
08-11-2015 11:14 AM
