Flywheel and Pressure Plate bolts part number?
I am going to do my clutch swap soon. Going to swap ACT to SOS here...
Can you guys tell me what are the OEM part numbers for Flywheel and Pressure Plate bolts? search didnt work for me here...
What other OEM replacement part do I need?
majestic honda has the diagram and parts list. you should also order drive shaft bolts because you WILL strip yours out. That will be the hardest part of the whole deal, also get a new throw out bearing and pilot bearing while its apart
Their website dont work for me for some reason
http://www.hondaautomotiveparts.com/...atcgry5=CLUTCH
I was also looking for the part number. I see a "BEARING, CLUTCH PILOT" but no throwout bearing part#?
pressure Plate to Fly wheel bolts 90034-689-000 BOLT, TWELVE POINT. You need 9 of these
Flywheel to crank, 90011-PCX-B01 BOLT (12mm). you need 8 of these
throw out bearing
22810-PCY-003 003 001 BEARING, CLUTCH RELEASE
http://www.hondaautomotiveparts.com/...CLUTCH+RELEASE
throw out bearing
throw out bearing
http://www.hondaauto...+CLUTCH+RELEASE
throw out bearing
Is it because Im overseas? the http://www.hondaautomotiveparts.com never works for me?!
I've got an SOS clutch and it's awesome. Stock feel but grabs really hard. I got the SOS 11lb flywheel too and I stripped the last damn bolt and had to grind it off and call the dealership to send me spares. Good luck, you'll need it.
joefish1298
11-12-2013 01:23 PM
