Feedback on Koni shocks?
They are decent. Even if you don't autox, get the autox valving...I believe it is an option when bought new.
Otherwise the standard valving is softer in compression. The softer compression has some pros and cons. Rapid transitions are not as crisp The autox valving will give compression closer to stock.
Rebound is adjustable to your preference.
