Easy Painting Solution V2 wheels painted
Originally Posted by jetboater,Jan 25 2011, 07:32 PM
fyi-----you can buy plastikote at both Lowes and Home Depot in the paint department
Originally Posted by it'S2klean,Jan 31 2011, 12:12 PM
They often dont carry the red if thats what your interested in. When i get home im going to do my Lug nuts, put them on my Honda Element as the S2k is in the shop, and if they hold up for longer than a week without a chip ill do my wheels.
Originally Posted by midnightmethane,Jan 31 2011, 05:04 PM
I see you chose not to do a detail tape job and painted some of the fender and bumper...is that because the plasti paint doesn't bond to the car's paint?
So the steps are.. clean the place your going to spray this on.
The cleaner the paint is.. the easier it is to peel off.
THen mask off the area that your going to spray.
From there apply light even coats and let it dry 15 min between each layer. I did 4 layers total so you can see my spray layers were very light. You want to spray thick on the paint area so its easier to peel off. Once its all painted let it dry for a few hours.
Then remove the masking tape. When removing the tape be careful it dosent peel off the spray you did and accidentally peel off the emblem.
After that clean up the car and enjoy the new emblems! Its the CR look without the CR cost.
Originally Posted by ans2k,Jan 31 2011, 06:21 PM
hum, so it shouldn't work on the rims then.
