Easiest Oil Change Ever - Oil Drain Valve
I've been using a Fumoto Oil Drain Valve for almost 3 years now. I love it. Even though oil changes were easy, I never liked the chore. With the oil drain valve installed, oil changes become too easy!
Steps (once the oil drain valve is installed)
1. Open hood
2. Place oil drain pan under oil pan
3. Unscrew oil filter
4. Open the Oil Drain Valve
5. Screw in new filter
6. Add oil
7. Dispose of oil properly
No need to jack up the car. No tools needed.
One time installation:
1. Remove OEM drain plug
2. Let oil drain
3. Screw in the Oil Drain Valve with provided washer
4. Do not overtorque the Oil Drain Valve.
I actually made a video of how easy it is. Even a girl can change her own oil!
[media]http://www.youtube.com/watch?v=gVmq8-obCEc [/media]
Oil Drain Pan used
Autozone carries an oil drain pan that will fit under S2000s lowered 2 inches as shown in the video. It costs about $2: Link here. The drain pan measures 3.5" in height.
FAQ
Q. How much does the Engine Oil Drain Valve stick out from the oil pan?
A. S2000s equipped with the Oil Drain Valves need not worry about ground clearance, as the valve extends parallel to the ground. If your oil pan does not scrape, then valve will not. In fact, many points of the frame are lower than the oil pan or the valve.
I love this product so much I'm starting to sell them.
Click Here for my post in the Sponsor's Section.
Or
Click Here to order
Promo:
Buy both Oil Drain Valve and my Keyhole Covers, and get $2 off your total order! Please use the code '2off2' during checkout. For those who have ordered before this coupon, PM me and I'll send you back $2.
1. Open hood
6. Add oil
2. Let oil drain
Oil Drain Pan used
FAQ
Or
Click Here to order
Promo:
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
Wow, pretty crazy. First I've heard of something like that.
While Fumoto will cover that under warranty, it would be a PITA to deal with.
Limited Warranty
Fumoto Engineering of America offers a LIFE TIME WARRANTY on its product, against faulty workmanship and/or material to the original purchaser (with proof of purchase). For any defective product, Fumoto Engineering of America will replace the product at no charge. Fumoto Engineering of America will also indemnify any consequencial damages to the engine/vehicle which are directly caused by the defective product. This warranty does not cover any damages due to misuse, abuse, negligence or accident. This warranty is valid only in the United States and Canada.
__________________
_________
_________
Yep, international shipping is available. You'll just need to select your appropriate country during checkout. Int'l shipping should be $5.
__________________
_________
_________
Mina's car and my car are lowered with less than a finger gap in the front and rear and the drain pan is able to fit. At Autozone they have a very low profile one that holds ~5.5 quarts.
If the drain pan doesn't fit, you can jack it up just a bit for the pan to clear, and at least you still won't need to get under the car to break the drain bolt.
__________________
_________
_________
