Drive Shaft Spacers
Drive Shaft Spacers
I've never noticed any vibrations from lowering my car. It feels like it was stock. Am I oblivious to the vibrations? Should I even bother installing drive shaft spacers? Will the spacers cause vibrations if I dont' feel any currently? Thanks.
The CV buckets can become pitted from driving at a certain ride height. If you change the ride height, the CVs will track in and out of these pits, since the CVs will sit in a different position in the buckets after the height adjustment.
Did you lower the car at relatively low mileage? Your CV buckets didn't get a chance to pit too badly, which is why you don't feel vibrations. Vibrations shouldn't start unless you change ride height again.
it depends on how much did you lower your car... if you change the ride height by like 1/4 inch somewhere down the line... then you might have issues. until then, you most likely don't need to worry about it.
