DIY: VIS Mugen Hardtop Install
Old 10-19-2011, 01:32 PM
  #121
s2guru's Avatar
Update: after 4 month of using the "foam like seal ) from homeddepot, i was having major creaks, top removed, and the seal were tore apart, glue of the seal was all over the place.. Back to using the rubber seal.
residue from the seal on the top.
more more issue. top was against the car the whole time, which destroyed the paint in that side of the car.
So i'm back to square 1, how the hell this seals goes.
Thanks guys
Old 10-20-2011, 05:28 AM
  #122
jaor.s2k's Avatar
thank you for the write up! i will be doing this during the weekend
Old 11-07-2011, 04:54 PM
  #123
mindphunk's Avatar
I installed mine today and something seems off. I installed the seals on the inside of of the "seam" and the top is off a bit. I washed the car and the windows leaked too. So I evidently need to move the seals to the outside of the "seam" and do something about the window seals too. Should I move the seals to the outside of the "seam" or more towards the middle? I don't think I'm getting exactly how they sit on the car.
Old 11-08-2011, 08:12 AM
  #124
mindphunk's Avatar
OEM?
Old 11-10-2011, 09:13 PM
  #125
nos4you's Avatar
Anyone have any links to purchase hardtop front latch shim kits?
Old 01-01-2012, 01:39 PM
  #126
MichaelSoeth's Avatar
On the seals u wanna go double layer on the outter side of the hardtop and in the middle where the rear window u wanna do one lower and higher end and put a seal right above the middle of the too what I did and have no leaks or window
Old 01-01-2012, 06:47 PM
  #127
jaor.s2k's Avatar
that's what i was thinking, cause i have some pretty big gaps in mine
Old 01-03-2012, 11:42 AM
  #128
dcmonkey's Avatar
how are people getting their tops to sit so flush and here can i get window seals for cheap????
Old 01-09-2012, 11:39 PM
  #129
dtkix's Avatar
hey suzukablues2k, you where I can buy the glass window? I don't really like the feeling of plexiglass
Old 01-10-2012, 05:02 AM
  #130
suzuka-blue-s2k's Avatar
Have you tried Spyder562? I havent been on here for a while since my s2k is gone, but that would be your best bet. If he doesnt have them you can call VIS and get them i'd imagine.
Back when I got mine the vendor had glass back windows, and he got his stuff directly from a VIS warehouse. So you should just call VIS directly and see if they have any glass ones.
Quick Reply: DIY: VIS Mugen Hardtop Install
