DIY: How to remove auxiliary 12V and it's panel?
Old 02-02-2008, 10:04 AM
bavarian06's Avatar
Default DIY: How to remove auxiliary 12V and it's panel?
Does anyone know how to gain access to the auxiliary 12V plug at the back of the center console?
The pin that holds it in place came out so I wanted to tighten it back in. I'm assuming I have to remove all the center console trims? Thanks.
Old 02-02-2008, 09:58 PM
meccjoo's Avatar
i would also like to know as my plug has come lose as well... ttt
Old 02-04-2008, 07:25 PM
s2kSEOUL's Avatar
From what I remember you don't need to remove the whole thing. Just pull the driver's side seat forward and remove the net hook screw and one or two other screws holding the plastic plate behind the seat off as well as whatever you find at the bottom edge of the console. Pull it forward and you can get your fingers behind it enough to grab the nut from behind.
Ha, I said "grab the nut from behind".
Decap1tator
11-04-2014 06:53 PM
s2knauer
07-05-2009 07:38 PM
taylorss2k
07-08-2006 07:00 AM
glass3ater
06-10-2006 06:19 PM
BioBanker
05-30-2004 04:03 PM
Quick Reply: DIY: How to remove auxiliary 12V and it's panel?
