Decat
Originally Posted by ScoobyWhite,Nov 19 2009, 02:46 PM
Hi
I would like to know if some one here already fit in the decat section one resonator so the car stay a little bit not so loud!!
Thanks
Thanks
Thanks for your help and interest
I want a test pipe with a resonator but something that really does not restrict but that get the DB value a little bit lower!!
Thanks
Thanks
Former Sponsor
Test pipes make the car louder if you have a cat in the car now.
If you have a non resonator test pipe than just pick up a resonated one and it will quite it down a little bit.
T1R makes a resonated testpipe but the resonator isnt filled with anything.. just empty space so it's still loud..
Im cutting the resonator soon, putting in some sound dampening material inside the resonator and re-weld it back to get th DB's down
Originally Posted by ap1_tot,Nov 20 2009, 10:08 PM
^^ nothing inside the resonator? why would T1R do that?
1)fiber material burnt/blew away: typical result of low end "glass pack" resonator
2)chambered design: direct air flow to muffler the noise, lots of OE applicator and older muscle car resonator are build this way, not very likely to be in this case
3) straight thru design: nothing "in" the path of the gas flow but there's an exposed chamber with perforated screen on the sidewall.
