Circuit Werks test pipe review
Old 08-23-2015, 07:05 PM
Arthas's Avatar
Was looking into picking up this same test pipe , but wasn't sure if I wanted to go with the resonated version or TP. Will the resonated version sound quieter ?
Old 08-24-2015, 07:43 AM
qbnlykwhoa's Avatar
I have the resonated version and I also have the 44mm UK mod done.
The car is actually pretty loud with that combo when I get on it but there is no rasp.
I can still keep it quiet but even then there is a low end rumble.
The smell is also not that bad. I thought it would be worse. I guess I'm used to it since my bike is catless.
Old 08-24-2015, 04:09 PM
Chuck S's Avatar
Received 1,238 Likes on 1,082 Posts
I run a Berk 63mm high flow cat in front of a Tanabe Medalion Touring exhaust. With a Gernby tune it makes a lot of power.
-- Chuck
Old 08-24-2015, 05:26 PM
superchargedk20's Avatar
Ap2 or ap1? Dyno plot of before and after?
Old 11-07-2015, 03:34 PM
longlivetheroadster's Avatar
Just got the test pipe for my 07 from the same ebay vendor Circuit Werks but it doesn't fit properly.
I use the donut gasket they provided but its overall length is about 1/2 inch too short so the 2 springs cannot be bolted on. The donut gasket that goes between downpipe and TP is too small in diameter even when i tried to shave it down.
I tried ziptying the springs to compress them for easier bolt on but it would not fit. I left the springs out to see how it is but im sure it leaks right there. The result is obnoxiously loud exhaust. WTF am i doing wrong?
Look at the gap
i can't even thread the bolt
so it goes on like this without springs but it leaks
Old 11-08-2015, 09:40 AM
Never mind i found a post in TP thread and it says not to use the donut gasket it comes with. So i used the original one and push the exhaust up a bit and it was a bit giving so everything's good now.
$85 well spent for the sound and performance. 90° bend CEL fix from Circuit Werks is doing its job on my 07. No CEL so far
Old 11-09-2015, 07:53 AM
qbnlykwhoa's Avatar
Yeah, I ended up using the original gasket. The one provided did not fit for me either.
Old 11-09-2015, 01:25 PM
114_ap2's Avatar
I dont understand why you wouldn't just get the Berk TP for just about $10-15 more. This way you'll have no fitment issues.
Old 11-09-2015, 04:13 PM
usmarinedelta's Avatar
Do these help with the low end 1st gear 2-3.5kk rpm "dead spot". Are they really worth it. I remember driving someone's long time ago and couldn't tell the difference except for dirtier exhaust tips?
Old 11-11-2015, 10:27 AM
I got this because of the 90° angle CEL fix. i did a quick search and it seems like other brand didn't have this. It's a must for MY06 and up with sensitive o2 sensor. Fitment is not an issue if u use original donut gasket. I wish i knew this before the installation.
I definitely felt the gain. Well worth the money imo
Quick Reply: Circuit Werks test pipe review
