Can my car be lowered?
I had my tires and wheels put on at discount tire here in Florida, and after they put them on the guy who worked there advised me NOT to lower the car because it will rub.
My wheel specs are;
Front
Offset: +62mm
Backspacing: 7.44"
Bolt Pattern: 5-114
Rec. Tire Size: 205/50-17
Rear
Offset: +62mm
Backspacing: 7.44"
Bolt Pattern: 5-114
Rec. Tire Size: 225/45-17
I'm not 100% on what size tires I have on the car, I know the front is smaller than the back. I'll have to check when I get off work.
I desperately need to lower the car it's stock height >_<
My wheel specs are;
Front
Offset: +62mm
Backspacing: 7.44"
Bolt Pattern: 5-114
Rear
Offset: +62mm
Backspacing: 7.44"
Bolt Pattern: 5-114
+62 offset and you cant lower the car... have you been to the gallery section of these forums? nowadays anything above 40 offset and not slammed is considered ugly lol..... you will have no trouble slamming that puppyy
