CAI on stock tune safe for 04-05? Too lean?
I'm pretty new to the s2000 but I have heard that the 04-05 has the leanest tune from factory? I'm slowly adding bolt-ons and eventually plan on doing I/H/TP/CBE/cams and go with Haltech Pro Plug-in. For the time being, I'm on stock tune but want to add the AEM V2 and a TP and catback. Will this create dangerous lean conditions on the stock tune or can I safely hit the track with it and not worry?
I did a 3.5" for about a year then got a 70mm TB and opened up the oem manifold to match when i put a Haltech in.
It will be fine. Dont do the throttle body until you can tune it though. That made it lean as hell. Hit 15.7 AFR at 7k rpm; 3.5" intake, 70mm TB, header, 70mm tp, 3" hks.
There's a few guys in FL that are running the 3.5" intake with test pipes that track and DD with no issues.
s2kturbofire
10-10-2003 08:12 AM
tenblade2001
10-02-2003 10:55 AM
