Biggest throttle body size that will fit OEM manfiold
How big can you open up the OEM manifold(non-DBW), without messing with the IACV ports? Seems very little people run throttle bodies over 64mm. Just wondering if the manifold was the reason for this.
I've done a lot of searching with zero results.
Is it 74mm at the IM side? I keep seeing people stating that they have a 70mm TB, yet the IM side of the TB is only 64mm. I guess some people don't know that the smallest part of the TB is the real size, not the opening.
Sorry this is the only pic I have before it was installed. I purchased a spare OEM intake manifold and had it shipped to Full Blown. They did the porting of the IM and supplied the 74mm throttle body also.
I don't have a before and after comparison in hp #'s as I did my build all at once plus I'm boosted now. I did make 511 WHP @ 15 PSI. (stocked/head block)
