Big Brake Question
Big Brake Question
Well since my car is gonna be down for a while im looking into changing the brakes. Now i like the Project Mu brakes but ive noticed there arent many kits that include the rear brakes either. Is there a way that i can get big brakes on the rear? Sorry for the noob like question.
There is, but you dont want it for at least 2 reasons:
1. It is unnecessary. It will mess up the brake bias if you just install and go.
2. You loose the ebrake. Wilwood supposedly had a solution, but I dont know if it ever materialized.
Originally Posted by modMonkey,Aug 1 2008, 05:06 PM
Correct. BBKs are mostly for looks. You gain a bit of consistency over a long track session. With proper fluid and pads, oem brakes are more than sufficient
Willwood: https://www.s2ki.com/forums/index.php?showt...&#entry13592640
J's Racing also has a rear kit, but it's a floating caliper just like stock, so it's probably not what you're looking for if you are going for looks.
Well i need functionality also. My car is going on boost pretty soon and she will be in the 700+ rwhp range. So im gonna need something to stop this lol.
The stock setup should be just as capable as any BBK setup. If you want kit for the front and rear, you would probably need to play with the bias.
Post some specs of the car
Banned
high hp doesn't necessitate a difference in braking technically. you will not be going any faster than anyone else, you'll just be reaching that speed much faster...even if you are drag racing or doing top speed runs a decent set of pads and good fluid will be fine since you will not have to worry about prolonged heat but just 1 big stop.
i would invest that money into reinforcing your car for that power along with lots of rear tires
