Best Test Pipe w/o CEL
Old 01-19-2010, 11:29 PM
RedSex2k's Avatar
Default Best Test Pipe w/o CEL
I apologize in advance if this has been covered before, although I didn't turn up anything specifically on this in my search. I wanted to know if there is a test pipe with a CEL fix that is less likely than others to throw a check engine light. I know that some, even with the fix will still have the problem. Does diameter make a difference? Any comments are appreciated.
Old 01-19-2010, 11:33 PM
splatter85's Avatar
pick any test pipe and add one of those $8 plug defoulers and you're set! Mines been running CEL free for about a year already. I have the 70mm invidia btw. >>>EBAY LINK<<<
Old 01-20-2010, 12:19 AM
ahrmike's Avatar
best way for no CEL? Get a early AP1. the newer the car, the more likely to trip a CEL, IIRC the ones popping CELs are 03+ (rarely) and 06 up (common) with a good defouler.
I have a '01 with ARK test pipe and spark plug defouler.. no CEL.
Old 01-20-2010, 01:33 AM
superpirate's Avatar
I have a berk 70mm, and have never had a CEL. Keep in mind though I have an 02 so that comes into play.
Old 01-20-2010, 06:58 PM
RedSex2k's Avatar
Good point. I guess getting an AP1 at this point is kind of out of the question
So when you say adding an $8 defouler, do you mean putting one on in addition to the cel defouler that's already included?
Old 01-20-2010, 07:32 PM
DFWs2k's Avatar
06+ are the hardest to trick, you should be good
Old 01-20-2010, 07:48 PM
Vik2000's Avatar
any TP is the same...
Old 01-20-2010, 08:01 PM
splatter85's Avatar
The test pipes with built in defoulers don't work as well as the added one. It's longer. The exhaust gas doesn't reach it the further away the o2 sensor is, this simulates the restriction from the cat.
Old 01-20-2010, 08:07 PM
00S2K01S4's Avatar
NT
Old 01-20-2010, 08:45 PM
keemaca's Avatar
is there a diy tp install ..ive searched but havent found one i know its easy but its always better to have something to go by im also planning on getting one soon ..
Quick Reply: Best Test Pipe w/o CEL
