Best size test pipe to fit on OEM exhaust
Old 12-14-2013, 07:21 AM
Saad_Z's Avatar
Default Best size test pipe to fit on OEM exhaust
Hi
Did some search but couldnt find any info regarding the question, what is the best test pipe to fit on oem exhaust/headers? 63.5mm or 70mm?
When I say best I mean, for air flow and power.
Thanks
Old 12-14-2013, 07:44 AM
Former Sponsor
Moddiction's Avatar
60 or 63mm.
Old 12-14-2013, 04:00 PM
first-s2k's Avatar
70mm invidia test pipe will work. I just installed mine with no problems. FYI, they have a version with the "CEL Fix"... it doesn't work, so just get the regular version and get a o2 sensor spacer to keep the check engine light off.
Old 12-14-2013, 04:21 PM
Former Sponsor
Moddiction's Avatar
If keeping stock exhaust don't get a 70mm test pipe. Get a 60 or 63.
Old 12-14-2013, 05:12 PM
S2KIrishman's Avatar
I would say only run a 70mm test pipe if youre planning on running a 2 3/4 or 3 inch exhaust
Old 12-14-2013, 08:11 PM
james0933's Avatar
60 right?...according to gernby.
Old 12-15-2013, 08:49 AM
06Estukay's Avatar
60 to 63 mm for stock exhaust.
70mm only if you're getting a 70mm exhaust.
Old 12-15-2013, 11:32 AM
LOVES2Ki's Avatar
+1
Old 12-15-2013, 06:23 PM
alSpeed2k's Avatar
look for a thread started by Gernby, he's done lots of tests on this and a 70mm won't be as good for a stock exhaust.
Old 12-15-2013, 07:38 PM
Jeremy Clarkson's Avatar
Listen to Gernby
+2
Quick Reply: Best size test pipe to fit on OEM exhaust
